Not a 6, but, finally installed the Anti Gravity ATX20 today and am glad to report there is more than enough room to sit another one right next to it when I get a second one. I need to cut down the comically long hold down hooks, I took a m6x1.0 die and threaded them all the way down so I wouldn't have to source something new. Picking that thing up out of the box, you'd swear it's fake and empty (the stocker will break your back), but my voltmeter says 13.0 right here and the stock battery was floating around 12 if I didn't bump it with the Battery Tender over night once in a while. Over all, it wasn't as hard as I thought. I had some m6x35mm set screws that I used to make studs so I could secure those to the battery and not have to dick with screws and block nuts if I had disconnect it for any reason. I was able to remove the fusible link set from the positive cable end, but had to cut the loop on the negative side, which worked out perfectly as I didn't want to make new cables or crimp a new lug on it right now. Turns out the main cables are already 4ga, but I'll still do the Big 3 later on when I do the second battery.
I got tired of my Nokia 8.3 charging slow in the car, so I tried a Y cable to see if it could combine the older 2.4A sockets together, but it didn't. So I got a QC3.0 socket and it rapid charges now. You can actually turn it off with that touch button. 2 USB type A and one type C. Not really a fan of the blue, but it's in my center console and the lid is always closed, so, no biggie.
