Subscribed
-St7
-St7
Just had first oil change at dealership - they used Castrol 0-20W. I frankly had assumed they used the Moly version. Called after I got home, they said you had to request, and further it was $12/quart!:huh:That's just the thing - there IS something, well a LOT of things, different with the Skyactive engines. Sure, they'll be just fine without the Moly, but with all the new lightweight parts and precision and quality of each piece, wouldn't you want to do anything possible to keep it running as well as possible? Even if moly doesn't do anything, tough to say, but it costs no more than your conventional oil and lasts just as long - I say why bother with anything else.
At which point the tech would have still put the same 0W-20 bulk oil from the barrel in your car because its not like anyone is actually watching him.Just had first oil change at dealership - they used Castrol 0-20W. I frankly had assumed they used the Moly version. Called after I got home, they said you had to request, and further it was $12/quart!:huh:
Thats what I think they would do as well. Gonna start doing my own changes soon.At which point the tech would have still put the same 0W-20 bulk oil from the barrel in your car because its not like anyone is actually watching him.
Ok, so then why do so many Mazda dealers NOT use the moly oil? Sure, it's more expensive than the bulk 0w-20 semi-synthetic they buy in bulk which is most likely why they use it, but if they were going to face a rash of engine problems or failures because of that decision wouldn't one think they would be almost mandated by Mazda to use the moly oil?That's just the thing - there IS something, well a LOT of things, different with the Skyactive engines. Sure, they'll be just fine without the Moly, but with all the new lightweight parts and precision and quality of each piece, wouldn't you want to do anything possible to keep it running as well as possible? Even if moly doesn't do anything, tough to say, but it costs no more than your conventional oil and lasts just as long - I say why bother with anything else.
Just like Shell gasoline with the nitrogen - that's been proven to help engines but costs no more than normal gas - I make it a point to get shell any time I can because what's driving an extra mile for gas if it helps my engine go another 5000?
FL22 Coolant is an ABSOLUTE MUST for Mazda engines...especially for the rotary engines. The formulation is specifically engineered for the seals that Mazda uses when building their engines. I don't remember the name of the additive but Prestone will eat those seals over time. Therefore costing you more money in the long run. FWIW, this is just my two cents from what I've read and researched over the past couple of years. I'll pay a few $$ more for peace of mind.I would'nt risk it when it comes to the engine, will go with manufacturer recommendation 0w20. For my first oil change at dealer he even told me to stick with Mazda recommended radiator coolant , that I think is a bit of a stretch, I will use the regular Prestone brand.
Not necessarily in the latter case.The 0W gives thinner oil for cold start lubrication. And the 30 should give better highway, high speed, high temp protection.
