1 - 19 of 19 Posts
This will serve as an ongoing thread showcasing the progress of my build.
The thread will be updated continuously and the OP will be updated with current pics each time.
If I can help anyone please don't hesitate to ask.
The Mod List:
Airlift Performance Series Full Air Suspension
Airlift V2 Digital Management
Dual Air Zenith OB2 compressors (White)
Accuair 5 Gallon Tank (White)
Work LS406 19x8 +45 (20mm w/ spacers) and 19x11 +0
Achilles 225/35/19
Muteki extended closed end lug nuts
Rolled and pulled fenders
SPC Camber bolts
B2 Design 25mm Spacers in front
MV Tuning Lite Style Front Fangs
MV Tuning Front splitter
MV Tuning Side Skirts
MV Tuning Rear Fangs
MV Tuning Molded Ducktail Trunk
OEM Wind Deflectors Color matched
Avery Gloss black wrapped roof
Junction Produce Tsuna Knot
Tsurikawa
Junction Produce Neck pads
Flossd VIP table
Morimoto 6500k 55w HIDs
Led 3000k High Beam/DRL
LED switchback turn signals
LED Tag Lights (DD Cool white HM3)
Good work so far, keep it up :)
Jealous of the upgraded interior of the 2016+ whenever I see it.
Decided to go a different route for wheels.
Just picked these up. Super rare had to import from Japan. Super Star Agle Minerva 3pc in 19x8/9.5 +43. They will be getting re-lipped and much wider!
Just another question, did you note a decreasing of the dirt around the plate?
With the stock trunk sometimes, after a ride on wet roads, the rear results as the only completely dirt zone. I think that the bad airflow is the cause of this phenomenon.
Discussion Starter #13
It's honestly hard for me to say. I only had the car about 2 weeks before the kit/trunk went on so it's hard to compare. The plate area is the dirtiest part of my car most of the times though.
Discussion Starter #14
Picked up a set of dailies...
Borbet BMW Style95s
19x9 19x10 +24.
Redrilled so no adaptors.
Tires are Achilles 2233 225/35/19 all around.
No fender roll
Discussion Starter #19
Been a while since I've posted.
Added camber bolts, swapped wheels, threw on 1" spacers, installed my switchback signals.
The new works are already being rebuilt too.
On to pics
1 - 19 of 19 Posts
7 Participants
DragginFrame
