1 - 3 of 3 Posts
N
Guest
ok so i have seen a bunch of people with systems hooked up into their stock cd players. does any1 know how this is done. i have a 03 mazda 6 single cd player. so does any1 know how i could hook up a amp to that. i want 2 add some boom boom 2 my zoom zoom
no problem. this stuff has been covered numerous time before. do a search, or just browse through this thread. i see you're new to the forum, read through the stickies in the newbie section. if you're in doubt where to post, post in the newbie thread to avoid being flamed.
from the question im guessing you have never messed with car audio before.... so odds are your gonna take it to a shop and they will worry about it...
to answer the question.... you can buy a LOC (line out converter) which takes speaker wire inputs and outputs RCA cables which are the traditional signal to amp (red and white plugs) Also, most amps now a days have high signal inputs, for these u just run the speaker wire from your headunit to the amp and it does its own converting.... this is the method i use in my setup, avoids extra equipement which = extra ways to break
1 - 3 of 3 Posts
