Does anyone know the voltage of the signal for the steering wheel controls? I believe someone informed me it was 5v, but I just want to double check.
I plan on tapping a relay to the change track buttons on the steering wheel. It’s for a carputer project.
Second question is how to actually take the steering wheel control panel off, so I can get at the wires… anyone have a diagram or how-to?
Thanks!
Thanks!
I just wanted to check.... Do you know that SWC wire is a single wire with different voltage/resistance when each command is pressed?
i just found that out with the wiring diagrams like an hour after i posted.
Looks like i'll have to cut the damned wires, craaaaaaap. I just wanted to tap into it :(
Anyways, left it untouched in case anyone has any ideas where to grab the cables to cut and put my hackboard.
I'd say it's way more than grabbing the correct wires. If you're using it as a carputer, then you'd; A. need to create the software to properly use the commands and B. create the hardware for the computer to receive those input voltages/resistances.
You know? Sounds like a good project tho.
No, i know what I'm doing past that point.
I was just mislead by someone else into thinking that the buttons sent out a 5v signal, so that's what I assumed. I am wiring the button through to a 10-key processor board, which will be wired directly through to a usb port. Will interpret simple commands for change track, switch mode (just changing it to random). and that's about it. volume keys already work fine.
