1 - 18 of 18 Posts
Hello I'm new here and i own a mazda 6 from 2007 i want to change the oem halogen to oem xenon.
I noticed that de oem Xenon headlights have an extra plug, can anyone tell me what that plug is for?
Someone already posted something like this but there was no reaction to that post so thats why i'm asking again, i added a picture of the headlight.
Can anyone help me with this?
Thanks in advance.
Xenon is a gas, not a bulb, do you mean HID? Cause thats not an HID housing.
There are actually Xenon light bulbs out there and those classify as HID. The Mazda 6 Gen I has HID but not Xenon.
As stated in this article, HID's need to warm up to reach full brightness (like mine do), Xenon doesn't.
How would you call a Xenon filled light bulb? I'd call it Xenon...
Let's call them HID's, not Xenon's so everyone is happy... 😄 The Mazda 6 didn't come with... Xenon filled light bulbs.
Can't recognize your flag/location, I know many European models equipped with halogens also have the headlight in-cabin adjustment feature, what do you have?
If that plug is accessible, I could disconnect it tonight to see what stops working but it could very well be the adjustment motor, as already said.
And that is why I clearly said, Gen I.
2004 Mazda 6s Wagon ATX
I am going to add to my earlier statement that I believe it is a manual headlight level adjuster.
I think all vehicles in the European domestic market (not sure where you are) that came equipped with non-halogen bulbs had to have an automatic leveler. My Europe wiring manual shows this hardware located at the rear underside of the vehicle and I believe it is this plug that integrates with that.
I don't want to rain on your parade but I just have to ask WHY? The HID lights are way expensive, and offer no advantage over cheaper alternatives. We replaced our Mazda 3 Xenon housings with inexpensive regular housings and installed LED bulbs. This cost a fraction of what new HID housings and bulbs would have cost. The light output matches the pure white of the HID's, and the output is even brighter. In my opinion, this is a far better option, cheaper, and easier. But to each his own I guess.
I just went and checked. My 2006 with (non-Xenon filled 😂) factory HID's does not have that plug. That is the radiator side of the headlight, right?
That would also be the opposite side of the HID bulb section so it wouldn't be to control the height of it.
The other plug (the bigger one) looks exactly the same.
243027
There are Xenon halogen (you could buy them in the 90s in the square glass bulbs even) and Xenon HID bulbs. Every 6 has projector housings, but they don't fit both HID and non HID bulbs. This is why i asked, cause there's no ballast housing in that pic. But i think @DrFeelGood is right about the Euro spec for leveling regardless of bulb type.
Discussion Starter · #14 ·
Hello,
I'm from The Netherlands and i have the headlight in-cabin adjustment but i think the cables are integrated in the main plug but i will check it this weekend when i'm installing the headlight.
Discussion Starter · #15 ·
Hello I'm from The Netherlands,
Can i have a copy of the wiring manual or a link where i can find it?
Discussion Starter · #16 ·
Hello,
I Installed the HID Units and they work only the headlight level adjuster doesn't like most of you said, i will try next week to use that plug to connect to the headlight level adjuster switch in the cabin.
if that works.
This is the route my buddy will be doing for his incoming Mazda 6 project. The previous owner messed the headlights and he'll swap them with LED's. God knows what else the previous owner done. We'll take a closer look soon after we finished installing the bumpers and bakflip cover onto the truck tomorrow.
Discussion Starter · #18 ·
I got the units very cheap it was only €50,- for the both of them thats why and everything works. i just have to fix the headlight level adjuster. ill do that when i have the time.
1 - 18 of 18 Posts
