This is another DIY/Info thread that will hopefully point you in the right direction in deciding what product will work best for your 6, as well as how to install those parts after you've made your decision.
I was hoping to get this further along, but ran out of time. please feel free to link additional DIY threads that might help, and i will adit the first post so they are all grouped together. Do to board rules, please link only to 6club threads with how to's, or copy existing how to's (as i have from 6crew) to here giving credit to those that actually took the time to creat the write-up.
Note that some of these threads have aged a bit, new options are currenlty available in some cases. feel free to add that info in that thread, or notify a mod if you think the info should be edited into the first post of that particular thread.
Lets start with the info part of things:
Check here for all suspension Torque specs in one place
Sway Bar info and options
A good listing of Coilover options
Spring options/info
Current DIY/How-to Threads
Rear Sway install
Intalling Springs/Shock/Coilovers how-to
Koni shock upgrade how-to
Replace lower control arm
Spring options/info
Rear Sway install
