1 - 2 of 2 Posts
Hi, I am very curious I have everything plugged in and ready to go for my subwoofers. It’s all put in through the door speakers. My only problem is I can not get a signal for my amplifier for the subs to turn on. Is there any signal wires that turn on and stay on while the car is running? If so, please please please let me know ASAP on where, how to get to it, and anything u believe you I would need to know to get the signal to turn the amplifier on!
You have bose or non-bose?
Some LOC (if you're using?) have line sensing and incorporate a remote turn on.
If you're using hi-level right into the amp some are auto sensing with a setting change on the amp.
If you just want a basic remote turn on into the amp's input you can use any +12v IGN power source, including an add-a-fuse in the fuse panel if you don't want to splice anything so that the amp will be on whenever the car is on.
The best way to go depends on what you're working with and install method chosen.
1 - 2 of 2 Posts
