1 - 12 of 12 Posts
As you can tell from my sig i usualy got wqith some mid range Fosgate subs. I listen to mostly rock. I am look at some other option for the GTO. I am thinking of going with 1 12 because the space is go limited. I was looking at 12" Adire bramha but can't seem to find it in stock. I have arround 1000w rms @ 1ohm to feed subs. Any other suggestions?
IDmax v3
Oz Matrix
In that case, I would probably recommend the first two of my options. Kicker would probably be ok (although I would probably do a little bigger like 1.5) but orion may need more power.
Best price out of the bunch(with warrantyand good customer service) would be the SS Rl-p but you can find the L7's for fairly cheap on ebay.
Elemental Designs 13Ov2 From everything I've heard/read, and my experiences with their Kv line, there's no doubt in my mind this is a top notch sub.
I'm really happy with my dayton too. RS12 High Output. I have mine in .75 cubic feet with 600 real watts going to it. With more power, I can only imagine it'd get better. Of course, this probably won't work in your application since it's only available in a 4 ohm SVC
Elemental subs are made by Image dynamics. Still great subs but in your case, ID MAX is he way to go. Even eclipse titanium is a good choice.
Daytons are great for the price
Eclipse and soundsplinter use the same oem manufacturer (hint hint ;) ) Plus Ti's, from what i hear, sound better ported and in a larger box than the space he has available.
IDMAX and Daytons are nice though and would fit.
Or just go direct to tc sounds.
Also my friend has a ti sealed and is only giving it 500 watts and it sounds great as a sq application. Ported would definatly be louder though.
As far as I know, TC Sounds only manufactures and sells in quantity. Soundsplinter, O-audio, and maybe some other small companies are the best deals you can get for their subs in small quantities.
I would also vote the elemental design, its a very good sub.
For more money JL w7 is also a good choice, but its quite expensive.
1 - 12 of 12 Posts
