I agree with not running 100% E85 but you should be fine running no more than 1/3 of a tank of it mixed with Premium Fuel. FYI, E85 is perfectly suited for FI cars being that you get a higher octane plus the fact that the exhaust temps are lower. The only problem you will see is a decrease in fuel economy and it you use too much in the tank you can lean out the F/A mix due to the car needing more fuel to do the same job as a regular gasoline.Do not, and I repeat, DO NOT, run E85 in the MS6, or any other car that's not equipped as a "flex-fuel" vehicle. Not only will you screw up your engine, but you'll void the warranty.
If you read your owners manual, its specifiacly says not to use and ethanol blended fuel with more than 10% ethanol.I agree with not running 100% E85 but you should be fine running no more than 1/3 of a tank of it mixed with Premium Fuel. FYI, E85 is perfectly suited for FI cars being that you get a higher octane plus the fact that the exhaust temps are lower. The only problem you will see is a decrease in fuel economy and it you use too much in the tank you can lean out the F/A mix due to the car needing more fuel to do the same job as a regular gasoline.
Feel free to read up on this...
http://forums.nasioc.com/forums/showthread...p;highlight=E85
Has one tried it or a small amount in the MS6? 105 octane could be fun. I used to use E85 in my 2005 Explorer and it really helped the butt dyno...of course it was a FFV.
I think you a little off here you will see MORE power at the cost of gas milage due to more fuel having to be used becuase of the lower energy density.It hasn't been mentioned yet, but ethanol has a lower energy density than gasoline. Even with the higher octane rating you'll see less power and worse fuel mileage while running E85.
Please read.I think MLuddyJr is right.
The energy density is based on the reaction between the fuel and oxygen. To compare apples to apples, both fuels need to be burned at stoichiometric ratios for a proper calorimetric rating. So, despite the ethanol running at a (comparatively) rich mixture, it's still stoich in both cases.
I think you're thinking because you have to run a richer mixture with ethanol, there's more ethanol in the chamber compared to how much gasoline there'd be. But, I think the extra power isn't from having more ethanol due to the richer mixture, but rather because as others have said, it burns faster, which allows for more ignition timing comapred to gasoline.
So, at the same ignition timing, gasoline will always produce more power than ethanol because of the higher energy content.
That is a very interesting read.
Normally I wouldn't, but this individual has been running it in his car for over 4 years. Here is the updated link for you to read up on.Yeah, I've read that stuff before.
The first link doesn't work, and I wouldn't consider a messageboard a reputable source of information anyway.
In the second link, all it says is that ethanol has a higher octane rating compared to gas, but has a lower energy content. How does this support your argument in any way, shape, or form?
...you will see MORE power at the cost of gas milage due to more fuel having to be used becuase of the lower energy density.
...it does support my argument that you will see a higher HP as stated in the second link that Ford has seen a 5% increase in HP on their testing.
