1 - 20 of 24 Posts
Stereo upgrade project 2016 M6 Touring
Figured I’d start a post as a place to log my progress. I’m figuring that this is going to be a 6 month project if I am lucky.
Goals aren’t that crazy:
Keeping factory HU with PAC aoem-maz2 for integration.
Infinity kappa 6.5” three way components in the front doors / dash using factory location.
Kicker comp RT shallow 10 in the trunk above the spare.
Amp is a Rockford Power t1000-4ad, which will give 250w to each door channel, and 500w to the sub. I plan on using HU power for rear fill.
I’ve done lots of stereo projects in the past and each has something I end up regretting. Usually because I get impatient trying to work fast. So I’m giving myself all the time in the world for this one.
Discussion Starter #2
Rough mock up of box and amp rack
Test fit of carpet
Getting started in earnest
Top of box is cut
Starting the fiberglass work
Popped the glassed-in bottom out for further coats on the inside
I strongly recommend figuring out a way to get forced ventilation (airflow) through the amp section of that box; I suspect you're going to regret it in a major way down the road if you do not. You'd be utterly shocked at how fast electronics that are running material amounts of power get hot in confined and reasonably-insulated spaces (which that space definitely is and will be!)
Plan is to build a new carpet piece which will have integrated mesh venting for the amp rack and the sub. Will also (maybe/probably) run a cross ventilation fan like PAC CF-1. Like I said it's gonna be a long process!
IMHO two small box 12V fans (e.g. 80mm) at opposite ends of the box (one push, one pull) wired to the amp turn-on circuit so they run when the amp does and establishes a positive airflow through the amp box. Fortunately they're trivially and cheaply available (PC fans are 12V.) That'll do it; you don't need a lot of airflow, but you do need positive airflow. Sleeve bearings are fine if they're mounted vertically.
This is going to be nice.
How is your tuning going to be achieved? Are you going to run a processor of some sort?
As of right now no tuning. Trying to keep it simple. Front stage will be well powered passive three way, rear fill from HU power, modest single sub in the trunk with adequate power.
Haha sadly 99% of my listening in the car these days is podcasts anyhow! This is more of a passion project than anything else ... a chance to take it slow and get as close as I can to something I’m happy with, as a white collar shade tree hack who is relying on his 12v self-training and 30 year old middle school shop classes (supplemented with some YouTubing).
Dunno about you guys but I feel like 75% of my “work” on this sort of project is just staring at stuff.
Discussion Starter #10
Glued and screwed
Decided to use the router for some cross vent holes on the amp rack while I had a jig set up.
On a GT, I'd personally leave out the PAC. It seems appealing because its plug and play and does supposedly work even on the BOSE models, but jt will be reducing an already line level signal down further which allows noise and distortion to be more easily introduced to the signal. If you want you can use the wiring harness that comes with the PAC so you don't have to cut into the factory wiring and can just cut into that instead, but don't use the actual hi-lo converter box.
With the BOSE system you have easy access to line-level 4 channel audio that is differentially signaled directly from the head unit (so 8 wires total) at the BOSE amp end of the factory cabling right under your passenger seat. I just did a whole system upgrade on my 2016 with BOSE and have the factory wiring connected directly into my amp and it works perfectly. I also kept the stock head unit since it is so integrated with various vehicle features and Android Auto already provides everything I need entertainment wise.
I analyzed the entire system and documented all my findings, including some wiring diagrams that are a lot less vague than the standard ones found in the workshop manual. It may help you out:
https://forum.mazda6club.com/electrical-hvac-lighting-audio/440044-2014-2018-mazda-6-w-bose-full-system-breakdown-analysis.html
If you just want the diagrams, skip to the bottom.
It has been a while... good to see the progress. Why is it that they didn't include a subwoofer? Or there is already one?
The Volkswagen golf has one in that position.
Discussion Starter #18
Amp / crossover rack is wired up. Doing everything with quick disconnects so I can pull the box in the event I need to get to the spare.
1 - 20 of 24 Posts
