Hey, I have a 15' Mazda6 that has a soft steering feeling for the first 5° L or R when steering. The problem started around 35k and got worse after changing the tires. Then it progressively got a little better over the next 30k until I just changed the tires again. The wheel feels like the steering is sloppy but the turning is actually responsive, the car moves but I can’t feel it in the wheel. It's most noticeable on the highway and it produces memory steering. Any point within the center 10°, the wheel direction will hold and the car will follow…so, I will be on the freeway and input a 5° R turn to change lanes, let go of the wheel and car will keep going to the right. Then to I will have to input again to bring the car straight, the car tracks straight if the wheel is pointed straight. I have had the car aligned 3 times, had a professional steering & alignment shop check the struts (they assumed it was the caps binding), tie rods and links. They drove it around with a scan tool to verify the Steering angle sensor was properly operating and centered. The shop thinks its Electronic Power Steering (EPS) related and I tend to agree, so I took it to the dealer and they said because there are no Diagnostic Trouble Codes, it’s not EPS related.
So, I have seen the wandering issue thread from DEC 21’ and that guy replaced his whole rack which would have of included the EPS motor, I believe? What about the torque sensor? Also, does anyone know if the EPS module get replaced with the rack? Can you reprogram the one in your car currently? Does anyone think I’m going down the wrong path thinking it’s module related? To me it feels to me like the EPS is acting like the car is in a parking lot when I’m on the freeway and its providing assist when I don’t need it.
Could it still be something mechanical that the shop missed? Thanks for any help.
