1 - 3 of 3 Posts
So could my starter be bad if everything turns on in the car but I don't hear the click click click sound
Check your battery's health first. The voltage and amperes. Do a load test.
Then;
  • Your fuses and relays related to the ignition system.
  • check all cables going to and from the starter. Poor connections due to physical failures and/or corrosion will give you issue. Double check your voltages. Clean your grounds.
I would bench test the starter to confirm. Most parts stores can do that at no charge.
(╭☞ ಠ ͜つ ಠ )╭☞ r=1+sinθ
1 - 3 of 3 Posts
