I'll give it a go but don't understand your comment after the "high crank case pressure"? This is insight of what is happening with high C/C pressure.
Did you get a CEL for this? High crankcase pressure is excessive pressure called blow-by, which is result of worn compression rings, compression gasses blowing past the compression rings and into the crankcase. This will be caused by very dirty oil not being changed at recomended interval, also messing up the PCV valve in the process. A tight engine will have very little blow-by, the cranck case is purged by the PCV valve located under the intake manifold on the 4i and to service it you have to remove the IM. Not to hard a job, check posts if necessary. The PCV valve is essentially a check valve, if you can find the hose to it, you should be able to pull air through it from engine but not blow back through it. This is info from service manual and does not give picture of actual location that I could find anyway.
