Yeah, man... We was workin' on a trade, but I knew it was to good to be true. Both, F/R sway bars FTW!!!Sorry dawg! Once we get warmer weather or a lift I think this is as good as on![/b]
I'm not sure, but I know the rear bar looked like almost 2x the thickness of the OEM rear bar that was in there. That rear sway and the springs dramaitcally changed the handling so much that I didn't think there was much room for improvement. Apparently there is. I can't wait to have it put in now.my only reason i wouldn't have thought it'd be a huge difference is isn't it like 3-5mm difference from the stock to aftermarket front sway bar?[/b]
ENVY is runnin' thick in my blood, but I'm happy for you at the same time... :nana:I'm not sure, but I know the rear bar looked like almost 2x the thickness of the OEM rear bar that was in there. That rear sway and the springs dramaitcally changed the handling so much that I didn't think there was much room for improvement. Apparently there is. I can't wait to have it put in now.[/b]
First off the the stock bars suck! Whatever aftermarket one you choose thats all your prefrence, When I removed mine the bars were not the best of quality looking bars I've seen, If you want I can post pics of the stockbar and bushings. N-E ways here are some specs:my only reason i wouldn't have thought it'd be a huge difference is isn't it like 3-5mm difference from the stock to aftermarket front sway bar?[/b]
Eibach .................... Available yet?
Whiteline.................:frt 24mm / rr 22mm, or 22 w 2-hole adj
MS6 oem ............... frt 24mm (fit, cheap?)
[ /quote]
huh? :huh:<div class='quotemain'>
[ /quote][/b]
It's too bad you, Justin6s, and I can't get the front bar on your car on SundayI haven't really had a chance to test out the car until very recently. I took the car to the body shop 2 days after I got it back for the bumper repair, and it's been icy and snowy over the last 3 days or so. Driving to lunch today down the winding road rated at 25mph and snapping corners off at 40+ was VERY fun. Adding just the rear bar and springs has changed the car SO much. I can't wait to add the front bar now.[/b]
It needs to be on a lift to do it, and there's no lift in the garage we use. :tear:It's too bad you, Justin6s, and I can't get the front bar on your car on Sunday[/b]
Well damn, I didn't know the bar came with grease. I bought my bar used though, so either the guy forgot to include it (which probably happened), or the shop where I took the car the first time to have the stuff installed (who couldn't do it) kept my grease.LapisLazuli: Did your RB sway bar come with grease? Mine didn't come with any and I thought it was supposed to.
**Edit: Nevermind, I found it stuffed under the flaps of the box.[/b]
Sounds like a common symptom people had with my old car when we put aftermarket swaybars on with polyurethane bushings. The grease that came with the kit would wear away too fast and the bushing would squeak when the bar rotated. Using antiseize as a lubricant fixed the problem.UPDATE:
I had the front bar installed. Now when I hit bumps at any speed, but especially speed bumps, I hear this squeaking noise like my springs are squeaking or something. This didn't start until the front sway bar was added though.
Advice???
Thanks![/b]
Any updates on performance? Please do tell.Justin6s and LapisLazuli6 are helping me install these on Sunday:
I think the car is going to feel like a whole new car afterwards :yesnod:
We have:
Racing Beat rear sway bar
Mazdaspeed hatch springs
CP-E motor mount
Smoked rear reflectors
Yeah, after nearly two years, the grease is wearing away for both my front and rear sways. Especially in the cold, when I shift, I can hear the squeaking noise.Sounds like a common symptom people had with my old car when we put aftermarket swaybars on with polyurethane bushings. The grease that came with the kit would wear away too fast and the bushing would squeak when the bar rotated. Using antiseize as a lubricant fixed the problem.
-Nik[/b]
I thought it would too, and maybe it does a little, but I didn't have any problems in the 3+ yrs. I'm installing the rear RB bar this weekend and plan on using the antiseize like I have in the past.Yeah, after nearly two years, the grease is wearing away for both my front and rear sways. Especially in the cold, when I shift, I can hear the squeaking noise.
Wouldn't antiseize material eat away at the polyurethane bushing? I thought only certain type of grease can be used for these bushing.[/b]
Ahh, I also noticed your location. This squeaking noise occurs only when it's cold. During warm weather, 60+, I can't hear the squeakin noise. So I don't know if the anti-seize material would help during the cold season.I thought it would too, and maybe it does a little, but I didn't have any problems in the 3+ yrs. I'm installing the rear RB bar this weekend and plan on using the antiseize like I have in the past.
-Nik[/b]
