1 - 1 of 1 Posts
I'm in the middle of replacing the front pads.
I purchased the hawk performane pads.
They fit but......
there is no holes in the top of the pads for the spreader springs.
Has anyone assembled these with out the spreader springs?
Secondly, the shims are mounted on pins that are swedged. the replacement pads have a shim swedged on them also. Am i correct to assume the hawks are just a bit thicker as not to need two shims per side. They came with one shim per isde mounted on to the pads.
Thanks Phill K.
1 - 1 of 1 Posts
