1 - 13 of 13 Posts
I NEED HELP AGAIN, MY SPEEDOMETER IS NOT WORKING AND IT IS NOT READING THE MILES, DOES ANY BODY HAVE ANY IDEAS OF WHAT THE PROBLEM MIGHT BE. PLEASE HELP.
my dome lights do work i have checked all my fuses and they are all fine also. everything on the dash works fine with the
exception that my check engine light is on and my tcs off light wont go off and there is one with a litthe car with curvy lines behind it on also.
I NEED HELP AGAIN, MY SPEEDOMETER IS NOT WORKING AND IT IS NOT READING THE MILES, DOES ANY BODY HAVE ANY IDEAS OF WHAT THE PROBLEM MIGHT BE. PLEASE HELP.[/b]
Did you ever find out wye your Speedo wasn't working
Do you have any lights on? Is the car throwin any codes? It could be either your TCU (Trans control Unit) or VSS (vehicle speed sensor). I had a Hyundai that did this quite often, fault in the technology with their "fly by wire" throttle system.
When I removed my car's battery (in 2 occasions of positive first and also negative first), odometer, fuel meter, temp. meter, trip meter and all other instrument indications got reset. Even after connecting back the battery, these readings are not coming. Some of the readings (fuel, temperature, speedometer and tachometer)are coming some times started and were running throughout that running time of car. Once car is stopped and if immediately started, again coming and started after some times, not coming. Means as a whole during this one week 3 or 4 times it appeared. My car is Mazda 6, 2007 model.
ever get this solved? i have tcs light on and no speedo also, getting ready for a 1200mile trip and really need to fix it this weeek!
I have the same issue. The speedometer and odometer not working, TCS light is on. Dome lights work and the dash lights work.
All fuses are good. 2007 Mazda 6 AT
Hi mcjas63
Did you figure out the problem you head. I have same problem as you posted.
Much appropriate if anybody can help out.
Ive got this problem with my mazda 6 2004, my speedometer not working. But there were time that it works when tcs light is on. What could be the cause of this?
You might have a faulty speed sensor. I don't where it is on Mazda but on our CR-V 98, it is attached to the transmission. It is a spur gear and each revolution has an equivalent speed.
Another possibility is that the instrument cluster is faulty.
1 - 13 of 13 Posts
