1 - 20 of 48 Posts
SEE PAGE 3 FOR UPDATED DYNO RESULTS
got my baseline dyno today, I dont have any mods on the car. I did have the reflash done on 8-7-6, and it is the most current version available as I had the dealer hook my car up today to check for an update - there is none.
Anyway, happy with the results. Runs were done on a dyno dynamics machine, which will typically read lower than a mustang dyno, and much lower than a dynojet. It is a great dyno to tune on though.
243.8 whp and 262 wtq
With an 18% drivtrain loss, which I think is conservative for an AWD car - 243.8 awhp indicates 297 hp at the crank. ~262 wheel ftlbs indicates 320 crank torque ftlbs.
This should settle the debate that the reflash lowers power. Boost still spiked to 17, held 15 to about 4400. Between 4400-5700 it was slowly decreaseing from 15-13.5. At 5700, it started to nosedive ending at about 4.5 lbs at redline.
I did try to attach the dyno graphs, but it says the file is too large - anyone that cares to help me resize them will allow the rest to see the graphs. please PM me if you want to help. I could email them to someone, and then they could post them if necessary. I have the Hp and Tq curves on one graph, and the boost curve and AF curve on another graph.
By the way, this was done with 93 octane Shell gas, with around 80-85 degree temps during testing. There was a fan blowing on the radiator, and one with ducting attached to it to the intercooler. The hood was open during the tests.
[Editted by Mazda Gremlyn]
Here are your graphs as promised. Click them and you will get the larger version.
Sounds good, too bad you didn't have a before to see if the reflash actually helped power.
Nice numbers. Although I am usually not one to check math, I came up with some different numbers.
243.8 @ 18% loss = 287.68
262.0 @ 18% loss = 309.16
did I do the math wrong? I just took
297 x .82 = 243
320 x .82 = 262
whatever, the engine is still making good power after the flash.
You are doing it backwards, the % comes off the flywheel numbers.
297 x .82 = 243
320 x .82 = 262
Nope, wasn't your math...twas mine.
Reason number 457 "not" to show up to class drunk :huh:
E-mail me the pictures and I'll get them posted for you (e-mail in profile).
email sent
I added the graphs in for you in the first post.
Discussion Starter #10
thanks alot - they look great although I see an error on my part. On the second graph, the numbers on the right side are for the Air/Fuel curve only - not the boost curve. I cut off the boost curve numbers on the left side which are on a different scale. I will try to send you a new picture of that. Sorry.
Well, I didn't make them look any different :p They numbers are impressive though!
Discussion Starter #12
ok, I sent you another graph that you can use to replace the one that is currently there. Thanks alot for your help, and in adding MS6 to the title. I didnt do that since I originally posted in the Mazdaspeed section.
No problem, happy to help :)
Discussion Starter #14
could you possibly delete posts 3-13 after fixing the graph? It would really clean up this post then as none of this info is relevant. thanks
Man now i REALLY think there is something wrong with my A/F's I have seen as low as 9.1 on my car so far <sigh> Nice run though.
They are really running this car rich. Carbon buildup will be a huge problem, some combustion chamber cleaner will be needed on a regular basis.
Discussion Starter #17
as you can see, my A/F drops below 9.9-1 also, which is the lowest that the wideband will read. So mine is no different than any other MS6. Although, the dyno operator said that most factory turbo cars do run this rich. He custum tunes many Sub's and Evo's here - basically all in the Missouri and central/southern Illinois area as this is the only awd dyno around.
I believe they are running this rich to keep intake charge cool, expecially the considering poor pereformance of the TMIC...leaning out may not net any more HP, but it would appear there's plenty of fuel for a MBC to crank up the boost some.
Hmmm, I guess it can always be calibration errors, but take a look at this dyno run from Fujita for their intake for the MS6. So who's dyno telling the truth? :irate:
I would think if Fujita was trying to sell more CAI for our cars, they would have higher numbers, don't you think? :huh:
Fujita is in Cali, we all know how this car retards timing with 91 octane.
1 - 20 of 48 Posts
