I have a 2006 Speed 6 and my coolant light came on the other day, checked the coolant level and its good and the car is not running warmer than normal. Any idea? Heard of the temp sensor going out but wouldnt that throw the cel and not the coolant light. . any input is appreciated
The sensor in the bottom of the coolant tank is dirty or the coolant is low. Are you sure the reservoir isn't so dirty it "looks" like it has coolant in it?
I pulled the cap and can see the coolant so i know its not low. Ill pull the sensor and clean it up an see if that fixes it. Thanks
coolant light
Tonight I had the same problem light even stays on at start up when it's cold coolant read 185 and gauge hasn't moved took on the high way let idle and reservoir is full wasn't hot nor he rad cap. Is it just the sensor? I just got the car and am really worried.
