The spare tire well is neither a circle nor a square- the edge along the rear of the car is a shape of swervy metal and goo, and the tire is in a semi-circle inset within a thin, rectangular frame that holds a plastic cover. The bottom is full of divets, as are the sides. What a mess!!!
Nonetheless, I'm going to try to use the spare tire well as a subwoofer enclosure. I have it all mapped out- my subwoofer will fit, protected, and I expect it will even sound good there providing I can find a way to air-tight the box. This will only work if I air-tight the box, but that's going to be the hard part! The actual well is ~26" accross with a rise in the center, making a center mount impossible. I'm going to put the subwoofer into the top quadrant (between the rear seats and the center of the tire well); and try to use the center protrusion as a brace. This will move the subwoofer far away from the rear of the vehicle, which is were I expect to have sealant problems. If I find it impossible to seal the rear, I will try to create sort of a slotted port, and its hould behave like a ported woofer enclosure. Total volume should be 2ft^3, at least, so a ported enclosure is actually preferable.
This means drilling many holes into my trunk (out of site and away from the underpinnings of the car- it's safe) to firmly attatch the baffel in place, and I haven't yet figured out what kind of substance I'll use to seal it. This baffel must be removable, and most foam or caulk sticks like glue.
I bet that this is very hard to picture. Nonetheless... any suggestions before this project gets underway?
Weight savings from losing the spare tire and subwoofer box should be at least 50lbs, and I get my trunk space back. Any suggestions for a cheap fix-a-flat kit? Guess I should buy one first- I assume Pep Boys or Auto Zone will have one for $20 or so.
