1 - 20 of 33 Posts
Went to the track today. Temp was about 55 degreese, wind was about 10 MPH cross wind. The 2 best results are as follows:
Thas 14.503 @ 96.56!!! Very good run and I would like to thank CPE for such a great product.
Mods were:
INJEN
CPE "fix"
Spint springs
225/40/18 Continental Sport 2's
18" Nakayama Higari's
That's it.
:D
My best MPH was as follows:
14.754 @ 96.92...
Nearly trapped at 97MPH!
Wow...I didn't see it in your sig, but have you ever had a dyno? From reading your tips, and now seeing these times you are obviously a great driver, but would just be curious to see some numbers to show what can be done with a certain amount of Hp/TQ.
HOLY SHIT. That is a sick time. I wonder what you could do if you had the full cp-e set up and headers.....
Those are some nice numbers! I have a similar setup, but hah, I only hope to get those kinds of numbers at the track.. gj gj
Great work! You are hitting some impressive times. I only dreamed of getting those in my 03 6s.
Great run!! That is good seeing how you told me that you could only do 93mph on 18's!!!! As a matter of fact i did a 95 mph past last weekend but with a 15.0 pass. I to just installed my MAFci fix over the weekend as well as my eibach pro kit springs. So will go back to the track and see if i can get you. Dam when i get the mph you had then you can get more time and mph. That is ok i am coming to get ya!!!! I see someone else is in the 14.8's as well with us!! I wonder what he has done to his car since he doesn't list his mods. Also you didn't list yours as well but maybe that was a choice of your own.
I ran a 14.8 in my 03 back to back. Only Eibach pro springs and 18s with some Yoko Parada's Spec 2 tires and a Injen CAI.
I just noticed that you ran a 14.7 @98mph!!!! What size wheels did you have on your car?
Opps wheel i read it again i noticed that you have a Speed6 now and that was a [email protected] DOH!!!
There is one guy who ran a real good time with only an intake. He's on the boards somewhere.
http://www.dragtimes.com/Mazda--6-Drag-Racing.html
I think I can get into the 14.4's but I need the CPE motor mount on the car and the Koni's installed.
I just notice that there is someone else that is in the 14's BUT with an ATX............. Hmmmmm no mods listed again. Well i am working on getting my 60fts down as i have been having real problems launching the car. I run my car with only 17 psi in the tires and leave about 2000-2200. I alos heat the crap out of the tires. It seems like it works. All of my times have been with it kinda cold on the ground so i can't wait til i can go with a little heat on the ground. Hopefully i can hook up better then. There is an import event on may 20-21 i will be attending and i will see what i can do then. Again good times!!!
FWIW, last October I ran a 14.92 with CP-E intake, and stock tires. it was also my first time to drag race, so I'm sure I could improve upon it quite a bit. launches sucked ass with the stockies. I plan on going to the strip this spring once I get the CP-E headers installed, if they ever come in.. and I don't have stock tires anymore, so I'll see what I can do
Do you recall which cars were next to you. Curious to know which cars got those numbers.
Discussion Starter #18
Heck you should go now to see what the times are before the headers. You defanately improved your rubber, so get a time on that.
Maybe I'll go this weekend. I don't want to go all too much right now because I don't want to waste tires.. just bought a house so I'm tight on money for a little while
I'd have to waste tires cause there's NO way around driving through the water.. so I have to burn them to get them dried before launching =(
Well just found my timeslip that I saved from that run.. ended up being a 14.93.
Don't laugh at my reaction time, was my first time there, wasn't sure when to launch in comparison to the green light on the tree :/
1 - 20 of 33 Posts
