Have anyone put their 6 on sn95 Mustang's tribars? Would be interesting to know how do they fit or look on 6 :D
Wheel Tire Automotive tire Motor vehicle Light
2004 Mazda 6s Wagon ATX
sn95=70.3mm center bore and mazda6= 67.1mm (would need custom ring)
TERRIBLE! :p
I suppose beauty is in the eye of the beholder. If you like those wheels then go for it! :p
Discussion Starter · #4 ·
Im european, so my GY 6 can run R15 rims :D I use R15 for winter tires. These mustang rims came in R16 ant R17, but main problem how the fitment look. Love tri bars rims on everything, a lot of guys put then on IS200 sportbacks, Rx-7 FC's, Hondas, Subarus etc.
You will need a centering ring for the hub. The Mazda uses a hub-centric wheel and it is necessary for stability. A local machine shop should be able to do this for you without too much difficulty. The last hurdle is the offset.
