I shift at 2,500 when grannying for mpg. Not bad. Hella slow start though.3200 normally for me. For more spirited shifts I go for 3500-4000. How does anyone shift at 2500? too much load on the motor when you shift that low.
I wouldn't be in 6th going 40mph even if you had a gun to my head. 4th or 5th is more like it. 6th is for 60+ imo. too much engine loadheres another question to add, what gears do you guys skip/use for casual driving?
3k rpm shifts, i go from 1st to 3rd 6th when i'm just trying to cruise around 40~
I skip second all the time, as I'm usually getting on it off the line. Highway merging I'll sometimes go 3 to 5 or 3 to 6 depending. Usually 5 though... I don't like 6th gear, lol.heres another question to add, what gears do you guys skip/use for casual driving?
i prefer to skip 2nd, going to 1st to 2nd at 3k is a bit jerky, its obviously not matching the way i'm doing itI never skip gears unless I am flooring it getting up to speed real fast when merging and then skip a couple gears.
I use 6th all the time once I'm at the speed I want to be at. If I want to accelerate, I downshift to the necessary gear, but other than that 6th is fine in my book. I don't require 60+ for 6th gear to be utilized.so 6th is pretty bad under 60 mph huh? my other ms6 buddy does it and hes had no problems, he does it in all his cars (hes driven stick way longer than i have). i'm only using like 10% throttle
can someone explain the whole "heavy load" in more depth in regards to the ms6? mechanically i can see why it would cause stress, but i thought these cars could handle it
