Hehehe..thanks...it's quite loud actually.Originally posted by Matt Mazda
Wow that ins't nothing![/b]
No doubt!Hehehe..thanks...it's quite loud actually.[/b]
Just got my Mazda 6 two days back. Really enjoy the ride.Originally posted by XTerm
Hi Jon,
I'm actually a member of MCS (Mazda Club Singapore). The trunk holds my amplifiers for the ICE (In-Car Entertainment) system
Stuff inside are:
2 Infinity Beta D300 2ch amps each one pumping out 1000w 4ohm driving a pair of momentum savage 12" subs
2 Cadence Z4000 4ch amps 150wx4 Driving Velocity front and rear 6.5" components
2 Cadence QXR-7 X-overs for the 2 4ch amps (all component speakers are running active x-overs)
2 Cadence 1 farad stiffening capacitors
1 Cadence 7 band EQ/Pre-amp
Unless I can cubic print the centre console of the car, I'll have to retain the stock head unit.You can join the MCS people for outing. Just head over to http://zap.to/mazda
Hope to meet you sometime![/b]
Hi there!Originally posted by XTerm
Hi Jon,
Stuff inside are:
Hi Steve, I've got a couple of stiffening capacitors (1 farad each) that helps the sub-amps when they need power. However, you are right in that after a while of blasting with the engine at idle, the generator doesn't supply quite enough power. I am on the lookout for a larger generator (the 90 ampere one supplied issn't enough so I'm looking for a 120ampere one). Also, I'll probably change my battery to a Optima Yellow Top (for sustained power) once the stock battery gives up.Originally posted by Steve 6er
Hi there!
Great stuff. Just curious: have you done anything to add to the car's generator capacity? My experience in this field is that with heavy loads like these, you may run into situations when the car does not sufficiently supply both the sound system AND the rest of the car...
This could result in many strange side-effects...softly flashing instrument lights, the battery does not charge correctly...and so on.
Comments?
BTW: What do you do when you go shopping? You haven't much room left in the trunk!!![/b]
QUOTE
Hi there!
Comments?
