I think Haldex confirmed at the same time that per the MS6 tech highlights diagram, Toyoda makes the electro-mechanically activated version of the system vs. their hydraulically activated system. Still appear to be very similar systems.fusion has a different AWD system than the speed6.
fusion/milan/mkz use a haldex system, and the speed6 system supplier is still unknown.
a few months back a club6er contacted haldex and they stated they do not make our AWD system. there's a post on this floating around.
on that note, has anyone confirmed the supplier of our AWD system?
very similar awd system with haldex 2 to mention!I think Haldex confirmed at the same time that per the MS6 tech highlights diagram, Toyoda makes the electro-mechanically activated version of the system vs. their hydraulically activated system. Still appear to be very similar systems.
The video I saw also showed 100% of the drive going to rear wheels in turns, essentially changing the car into a RWD during cornering. This seems rather misleading, as I'm not aware of any AWD system that completely disengages the front wheels while turning.These animations are sometimes misleading. With open front and rear diff, it cannot adjust torque between left and right wheels.
I missed that. No way usual haldex type system could do that in turns ... you could get 100% rear on a start with fronts on ice.The video I saw also showed 100% of the drive going to rear wheels in turns, essentially changing the car into a RWD during cornering. This seems rather misleading, as I'm not aware of any AWD system that completely disengages the front wheels while turning.
Our car is only fully fwd at very slow speeds, such as if you are tooling around a parking lot. Otherwise there is atleast some power going to the rear wheels. I can't seem to find the thread where this was confirmed, but I remember reading it not too long ago.very similar awd system with haldex 2 to mention!
as far as i can understand the car in normal conditions behaves like a fwd??that s awesome also!!more fuel economy!
