Hey @Tom Roc - sorry for the delay on this, I was on vaca and the thread needed an approval for some reason.
Silly question but have you triple checked that your oil level is currently happy? I see you've tried resetting it a few times, where did you reset it from, the navigation or the "Info" button on the cluster? There's definitely a way to turn it off because mine has never been on.
Nah, the info button is where you need to do it from.
If/when you go into Settings from the info button, could you try turning it on, setting some distance, then turning it back off again? Also, can you try looking into the messages under settings and seeing if there's a way to view/delete them? I've never got these messages so I'm not sure.
