B
Guest
Hey, I was thinking about upgrading the factory bose, but was financially limited and also the factory amp and impedences limit options without replacing it all.
I would love to do something like a JBL MS8 and my Alpine type x woofers in the door and my seas neo tweets in the dash from a previous car.
I checked on eBay this morning and there are a few examples sold on eBay for quite a bit of cash. Factory amp for over $200, and a couple examples of the door speaker going for over $100. If I could sell my bose amp for $200 and each speaker in the front for even $50 each, that pays for a used MS8 and gets me on my way!
Anyone have any luck selling the factory Bose?
If someone had a Touring they would have to run wires to make it work or if someone had a Grand Touring they would have parts to replace if they had problems with there Bose and they could get it much cheaper than buying at the dealership.
As a former MS-8 user I can say you'll likely be super frustrated working with it at first (I was), but when you get it setup correctly it will sound amazing. I'll be interested to know how this goes for you! Mazda likes to simplify things in their audio system design so the head unit should have 4x pre-amp level outputs to the BOSE amp which you can just route directly into the pre-amp inputs on the MS-8. Not sure if you're planning on running external amps or not, but as you might know if you plan on using the MS-8s internal amp for your speakers it's not all that powerful (20Wx8 @ 4 Ohms & 30Wx8 @ 2 Ohms). Might be worth thinking about keeping some of the BOSE speakers if you don't already have replacements for all of them just so you have matching power. The MS-8 will work its magic and make a difference regardless.
But to answer your question I'd think if your factory speakers are in proper working condition you shouldn't have any trouble selling them.
B
Guest
thanks, guys. The MS-8 sounds pretty complicated, but it might be worth it in the long run. The bose sounds fine for now, just curious about the future. I will probably just add a sub for now and see how that goes.
