The driver’s seatbelt warning light and beeping irregularly come on while driving my 2012 Mazda6 wagon. Sometimes more likely when turning left! When my wife drives with the seat moved forward, it beeps more regularly. If she moves the seat up or back a little it stops. Took it to a dealer and no fault found. Yeah, because it is irregular. Any thoughts before I start replacing each under seat connector, wiring or whatever?
You just narrowed it down to the wiring... unplug the connector under the seat and plug it back in.
Yes thanks. Unplugged both yellow and white connectors a few times. Even took the whole front driver’s seat out for a good look. I’ll cut and bypass the yellow 2 pin plug because it is the easiest. Then go from there and post updates.
