1 - 10 of 10 Posts
Needa be broken in, then I can post my findings.
By the way, has anyone successfully been able to insert those paper-clip-thin brake clips onto new pads (the ones that push the pads apart when not braking)? Tried for a while and ended up keeping them off.
before.
after. (i know it's in backwards)
braided brake line would always touch something if bolted same as stock, meaning rubbing would incur.
found it was better bolting to coilover.
congrats. I love my xdrilled and slotted rotors / upgraded pads / SS lines.
Only thing that you will notice without the clips is a little bit of brake chatter. no big deal. You get used to it in about 10 min of driving
Why not reuse the springs? I just did one of my four wheels, and it was a tad tricky to reinstall the springs. A third had would've helped. I tell you what is hard is removing those damn screws that hold the rotors on, wow. I used an impact wrench and destroyed one of the impact bits the second I pulled the trigger. I had to drill that MF'er out.
Discussion Starter · #9 ·
Couldn't find how to put those spring clips back in. We tried but nothing came of it.
Yes, the screws in the rotors were a beast. Broke four tips and even after use of the Impact wrench, had to wind up drilling one from each of the front rotors. Back ones were no problem.
1 - 10 of 10 Posts
