1 - 11 of 11 Posts
Good to hear, I was thinking about picking up a set of RX-8 wheels in the spring to put my OEM tires on (just ordered a set of snow tires for stock wheels). Was there any noticable difference in acceleration with the lighter RX-8 wheels?
wtf kind of file is it?
flash file of some sort
The car was a bit closer to neutral on track than the massive understeer while under heavy throttle....otherwise you can absolutely feel the linear rate of the spring under load.
The issue I had w/ this car is the lack of feedback...it's so smooth it's like you're on a cloud whereas I'm used to a heavily modified CRX on track (this was the cherry poppin session for the MS6).
1 - 11 of 11 Posts
