Reading Topic: Resonator Removal
I can give you a quick walk through on it:
- Remove the bottom bolts holding the splash guard in place underneath the vehicle on the driver side (10mm if I remember correctly)
- Then unscrew and pull out as many of the fender well splash guard fasteners as required to pull enough of the splash guard out of the way for you to get easy access to the resonator.
- Take same 10mm to the two bolts holding the resonator box in place. Once loosened you can pull down and away from those bolts and it will slide out, or you can completely remove the bolts.
And as alot of our Haynes manuals at work say about any type of repair for reassembly, repeat all these steps in reverse sequence. :)
haha yeah i noticed...i was thinkin about grounding when i was posting this, so i put it in electrical. my fault...thanks fordman...and if a moderator can remove it, that'd be great. thanks.
4 Participants
Indy MPS6
