1 - 3 of 3 Posts
I have an '07 6i and I guess the previous owner decided he didn't like his battery. I noticed my stereo turning off and on when driving so I check the battery and the positive terminal was off. The nut was completely stripped. So after much fighting I got the nut and bolt off and replaced, but it still is loose on the terminal. I guess next is to replace the connector. I went to my local auto store but the connectors there seem/fell very cheap. Does anyone know of a place I can order the OEM part from?
I would think what the store has would work fine. Once you tighten your cable to the terminal I wouldnt thinnk itd move anymore. If you want OEM Im sure your store or one nearby would have that too.
B
You should be able to get the OEM style at most auto parts stores. They are every bit as shitty as the OE ones.
If you are really worried about it, go get a set of terminals from a car audio shop.
1 - 3 of 3 Posts
