Hey everyone, i was switching out light bulbs earlier and i know i was supposed to remove the negative wire and i really felt bad that i didn't and hoped nothing would happen that dealt with the battery. Anyways, i couldn't remove it so i went ahead and changed the lightbulbs out but i made sure everything else was off. But i am still wondering how i would remove the wire form the battery. I saw a nut there i could turn but it wouldn't budge and i didn't want to deform the bolt/nut so i just gave up. Should i get a copper brush and brush it up a little to remove the residue around the wire (its a new car but there is a little white powder)? Then get some pliers? or another tool? and take off the bolt? And when its loose enough slide it off the battery thing. Tell me if i have the steps right, or if the connection is made to where you can just use pliers to pull off the wire from the battery. Thanks
10mm deep well socket is what I use. the white stuff of the terminal I don't get around here, but I don't live near salt water
yea, I think it's 10 mm socket or wrench. Just loosen the nut and you can slide the connector off the battery.
Mine was a pain to get off the first time, so when I put it back on, I tightened it but not as tight as it was originally. It's tight enough to stay on and not budge, but I don't have to throw out my shoulder getting it off anymore.
