1 - 20 of 56 Posts
Well its that time of the year where I'm thinking of getting a remote starter. I live in NYC and its getting pretty cold here in the morning. I was wondering if anyone has a remote starter here and which brand they have. I'm not sure how much I should pay for a professional install. I've heard VIPER alarms and remote starters are good. Anyone out there with remote starters?? Your advice is very much appreciated.
Anything from DEI is good...Viper, Python, Valet, Hornet etc.... I just ordered the new python 990 to replace my 871xp... I'm upgrading because the range on the 871 sucks, and the 990 is supposed to be 1 mile range...Install costs anywhere from 75-175 dollars depending on which one you go with, and you will probably need a bypass module too, i think i paid 60 for that.
You can get the bypass module on ebay for $25. If you buy a DEI product and don't have it installed by a DEI certified installer, DEI will not honor the warranty at all. So in other words, if you don't buy it from the place that installs it, no warranty.
No, most of the wiring is under the dash and drivers kick panel, then theres one wire and the siren under the hood
Are you guys installing these on manual transmission's? Does anyone have a remote starter on their speed6? Thanks for any info you can provide.
mine is on a MTX. There is a neutral safety wire on the 6 that won't allow you to crank the car in gear, but I haven't hooked mine up to it as of yet because someone just recently discovered the wire
I just receive my viper 791xv from internet todayand I'm going to get instal this week. Is it a good alarm? Did you used remte to start your car?
I've got the VIPER 791XV. I purchased it on yahoo shopping for $198, then installed it myself.
yes, i use it to remote start my car. i installed it myself because i wanted to save some money. it's is a pretty difficult install however and is very time consuming (10-12 hrs would be a quick install)
has anyone posted a detailed instructions on how to install a remote starter? how to take apart the steering column ?
thanks
Has anyone installed a remote start on a MS6 GT? I'm curious if there are any issues getting a remote start to work with the advanced keyless entry.
thanks
if you want to do it yourself, the factory option would be the simplest and least time consuming. There isn't a detailed remote start install guide anywhere because it would take hours to write up.
I have a Viper 791XV on my 6s. Don't forget that you need to get the Mazda bypass unit, I think it is a DEI model 555 if I remember correctly. You also need your valet key to operate it. And have your factory alarm disabled too. I love that alarm. I wish I could install it on my MS6. I never started my car with the key in 3 years.
Yomama you said that you wish you could install on your MS6, thats what i have. I think jd42 and i are both looking for more info on which models people have installed on their speeds. Pro's cons' , pain in the ass install? cost, modules needed , how it works with the advanced keyless entry etc. Why dont you have one installed on your speed?
2017 MZ6 GT Jet Black Mica
I have an 06 6i and I was told the aftermarket remote starts won't work because the remote doesn't work when the car's turned on. I was going to get OEM Mazda, which is $485 installed at Rosenthal Mazda.
1 - 20 of 56 Posts
