And, nothing will happen, cause its been out of production for 10 years. They wont start making parts for a recall like that.
Hi guys my Mazda 6 2009, 130k miles has severe rear subframe corrosion and complete failure. The right rear control arm is disconnected due to the rust. My car otherwise is in great shape. Is it a lost cause to repair?
We are currently dealing with the same problem with the rear subframe. Front was covered under warranty. Would make sense to me that rear should be covered as well but Mazda says no. Can’t find part anywhere and Mazda has no idea when they can get it. My mechanic has checked salvage many times and the parts he keeps getting from salvage have all been bad. So I think we need to figure out how to get a Mazda recall on the rear as well.Hi All,
I had the front subframe replaced in my 2011 Mazda 6, through the recall.
My mechanic now says the same level of corrosion appears in the rear subframe. I didn't have the chance to go under it myself and take pictures, but the thought is very disturbing.
Does anybody else have the same problem?
Thanks.
Hakan Toykoc
I'm screwed because my car has a salvage title mazda won't warrantee it. The car was damaged in the rear passenger door, insurance said the could total because the repair was too close to the car value which was false.We are currently dealing with the same problem with the rear subframe. Front was covered under warranty. Would make sense to me that rear should be covered as well but Mazda says no. Can’t find part anywhere and Mazda has no idea when they can get it. My mechanic has checked salvage many times and the parts he keeps getting from salvage have all been bad. So I think we need to figure out how to get a Mazda recall on the rear as well.
I do and it’s dangerously bad. I have many pictures and videos.Does anybody else have rear subframe corrosion problem, Mazda 6 2009-2012?
It would be great if we all could raise voice and reach Mazda to see if they'd consider a follow-up recall for the rear subframe.
Anyone?
It seems to be a common problem. I went to a junkyard to look for a "front" sub frame when my sons car's frame rotted out bad recently, causing the steering to be off. There was two cars there on the lot. One had the rear sub frame missingRecently, I noticed the same issue with my Mazda 6 2010. Something was hitting underneath when driving on bumpy roads making a strange noise. Then I noticed that the rear back of the car was sitting lower compared to the other side of the car.
When I took it to the mechanic, he told me that the rear subframe had to be replaced due to corrosion. Then I just decided to buy another car.
I was expecting to use the car a little bit more, since I was rustproofing it every year and washing it during the winters since I bought it used in 2018. I live in Ontario, Canada.
Has RustCheck worked out well for you? Green can or red can (if memory serves, here)? Do you brush-apply it or spray it?It seems to be a common problem. I went to a junkyard to look for a "front" sub frame when my sons car's frame rotted out bad recently, causing the steering to be off. There was two cars there on the lot. One had the rear sub frame missingand the other had a brand new front sub frame still on it. I couldn't believe it !
I decided to check with Mazda first to see if they would replace it and they actually DID!! Free of charge.
Now I'm looking for a rear replacement even though I'm soaking the rear frame with rust check undercoating and it still looks ok. Not sure why Mazda isn't covering the rear frame as well? It has the same issues as the front.
Good luck....
I called a Mazda dealer today.It seems to be a common problem. I went to a junkyard to look for a "front" sub frame when my sons car's frame rotted out bad recently, causing the steering to be off. There was two cars there on the lot. One had the rear sub frame missingand the other had a brand new front sub frame still on it. I couldn't believe it !
Good luck....
I use both spray cans.Has RustCheck worked out well for you? Green can or red can (if memory serves, here)? Do you brush-apply it or spray it?
It's available as an aerosol can, or in an approx. 1qt. can with a cap...
I wish I knew why some steels/steel fabrications rust in the manner you describe, i.e. by spalling-off in layers. Also, some steels, generally, rust at a ferocious rate, and others just rust at a very slow rate....
I found a lot of flaking rust on the rear frame and I tried tapping with a hammer to remove what I could, then soaked it real good with a green can of rust check. It still looks "ok" but not sure how much longer it will last.
