1 - 7 of 7 Posts
I realized after I bought my 2016 6mt that there are no vents in the back seats. I see in the gt that there are? Are there ducts that I could connect to if I replace center console? Has anyone done this?
Vents like, a/c vents? There should be two in the middle of the center console, facing the back seats. Are there supposed to be others somewhere else? The center console ducts run through the (drum roll) center console, all the way into the headunit and dashboard space.
Hi, yes a/c vents. My model doesn't come with them.
Will I need to buy everything from the dashboard space? Or will it be prepped to the center console? Thanks for the help!
Ah! Well you can find out real quick. Open your center console, and pull your cupholders straight up. You should look down and see if you have the tubing for it or not. It'll be a black tube that runs all the way back. Might be capped off in the console, might not. Not sure. I haven't seen a model without the middle A/C.
Dear
Have you done with your case ? Please let me know coz i have the same case
Regards
You're resurecting a more than 3 year old thread.... I am not sure the Original Poster is even active here any more. Active, last, more than 2 yrs ago... Does anyine else know the answer?
Related, I have heard that the rear a/c registers on the Touring and on the GT have notably poor airflow... I imagine one would have to pinch-back the front a/c registers to be able to chase some air towards the rear...
Comments?
'16 M6, 2.5L, ATX
Comments?
Comment: usually I'm in the driver's seat, but sometimes I check the air's temperature in the rear seats (by blocking the airways with my hand), and it feels good enough. Usually my dog lays in the rear seats, never complained :)
1 - 7 of 7 Posts
