Hey guys, if a 2003 6i has the front grill with the crome strip, does that mean that the rear has the crome piece aswell?
If so, is there a piece to switch that to the body color; like the front sport grill does?
http://www.mazdastuff.com/product.cfm?ProductID=1301
I found this, but no body colored piece. Does that mean you can just take off the "Crome rear finisher"?
Yes you can just take it off...but you will need one to put in its place. Not sure where you can get a body color one...maybe a junk yard car?
I just sold the chrome finished I had. Its really easy to take off. You will need I think a 10mm socket with a deep head b/c the bolt is rather long. Then under the trunk hood you should be able to look up under and un-bolt them. One is attached to the trunk light, but you will need to take it off. After the 3 are off just pull up and out and it should slide right out...Not sure what you would replace it with though....
Goodluck
Goodluck
So what did you replace yours with? Man, I wish they made a part the same color as the body... Geez...
When i bought the car it had the chrome finisher on it that was aftermarket. Luckily the guy kept the body color one and i swapped them out.
