1 - 3 of 3 Posts
Hi guys, I'm trying to remove the radiator fan from my 3.7L Mazda 6. (Still works, blade broke off and, as you might quess, vibrates like hell). I've got everything removed on the top side and have the fan loose (can raise it about an inch and a half)but is still hanging up probably at the bottom or something I can't see from the top. Anybody been thru this and can offer suggestions. Thx in advance for any help.
I think there is a rad hose wedged in a clamp at the bottom of the fan assembly.
Correct, I had to drain radiator, remove hose on driver side of radiator, then slide fan assembly towards driver side and lift that corner up and out. Thanks for the reply.
1 - 3 of 3 Posts
