1 - 20 of 30 Posts
Mazda6club.com: Sponsors
R1 Concepts Inc. is proud to offer Premier Series Mazda6 Rotors!
I am offering the Premier series rotors which are made with stronger iron cast metal (XG3500) for overall tension strength. The Premier series rotors which is the top of the line series out of the two that I carry (E-lines & Premiums). The rotors are cast with a 50/50 center split for better heat distribution. Premiers utilize a black Electro-coating finish applied on the hubs and inner vane structures providing long lasting corrosion protection. Original stock size, will bolt right up with no modifications needed. (we also have our E-line series available)
What separates R1?
Often Imitated, Never Duplicated. Here at R1, we take into account numerous precautions in machining rotors. We drill our rotors in house using state-of-the-art CNC machines and follow strict procedures and standards such as drilling between each vane structure. This will allow the rotor to retain its structural integrity and overall strength with optimum thermal transfers. We utilize smaller diameter drill bits for smaller diameter holes and each hole is counter-sink to add strength. You also have the option to go with slotted only or even a custom design with your own logo. Every R1 rotor that comes with slots will come with our exclusive "Diamond Slot design" (45 degree angle end points), to help release trapped debris. Our diamond slot design is also a good indicator for rotor wear. We also offer optional Cryo Treatment at an additional cost. (Cryogenic treatment is a process that improves the performance and life of the rotor by strengthening the metallurgy. This process will help to give an extra level of protection against warping).
*WARRANTY*
Here at R1 Concepts Inc, we stand by our products. We offer a one year warranty on warping and cracking on all R1 brake rotors due to manufacture defects and workmanship.
AVAILABLE STYLES
Slotted Only
Drilled and Slotted
Drilled Only
Dimple and Slotted
*Custom Engravings* (engraving cost may vary)
PREMIER SERIES ROTORS (ANY DRILLING PATTERN)
FT/RR: $230 SHIPPED (2003-2005)
FT/RR: $245 SHIPPED (2006-2013)
FRONT: $150 SHIPPED (2006-2013)
FT/RR: $285 SHIPPED (2006-2007 MAZDASPEED 6)
FRONT: $185 SHIPPED (2006-2007 MAZDASPEED 6)
FT/RR: $270 SHIPPED (2014)
FRONT: $175 SHIPPED (2014)
*Optional Cryogenic Treatment: $30 per rotor*
(We also carry our E-line Series Zinc Plated rotors for member who are are looking for a lower costing rotor)
BRAKE PADS
FT/RR POSI QUIET CERAMIC PADS (LOW DUST): $65 (03'-05'), $74 (06'-13'), $90 (2014)
FT/RR STOPTECH STREET PERF PADS (IMPROVED BRAKING): $85 (03'-05'), $100 (06'-13'), $105 (SPEED6)
FT/RR HAWK HPS PADS (IMPROVED BRAKING): $105 (03'-13') & $120 (SPEED6)
FT/RR HAWK CERAMIC PADS: $115 (03'-05'), $125 (06'-13'), $130 (SPEED6)
FT/RR EBC REDSTUFF CERAMIC PADS: $145 (03'-05'), $160 (06'-13'), $200 (SPEED6)
BRAKELINES
FT/RR STOPTECH STAINLESS STEEL BRAKE LINES: $125 (2003-2008)
BRAKE FLUID
STOPTECH STR-600: $14
STOPTECH STR-660: $22
BRAKE FLUID
G2 CALIPER PAINT: $28
IF YOU HAVE ANY QUESTIONS OR WANT TO PLACE AN ORDER, PM WOULD BE BEST.
PM: r1concepts
Email: [email protected]
Phone: 888.712.6623 ext. 7022
www.r1concepts.com
Please let me know WHEN you have Stainless Steel Brake Lines for the GJ (2014+) Mazda 6!!
I will definitely let you guys know when we have these SS brake lines available!
1 - 20 of 30 Posts
