Problems yes or no?
1 - 20 of 54 Posts
I want to keep this poll VERY simple.
I've not had a single problem in almost 4,000 miles, sometimes it seems like all we have are problem posts here, I'd like to see the real percentage of no issues versus real issues.
Now the poll is a simple yes or no, and for problems I mean something reasonably significant, not some small rattle, or a small paint run or a bad lightbulb or loose sun visor, get it?
nope, almost 3000 on the clock.
Nope, nothing mechanical (only had a trim peice that needed to be refit) and almost 10k miles.
Nope, no problems here other than the reflash, but I'm not counting that. I'm at 8,500 miles.
No real problems here. I had to have an evap purge valve replaced, but dealer was so accomodating that I almost felt good about it. I'm a happy camper. Jus' drivin'. :drive:
Almost 6,000 kms on mine and no problems (excluding the reflash, which doesn't count).
I do notice a slight clunk during hard shifts, which I imagine is a motor mount or something, gonna get it checked out soon.
I voted yes because of the power loss issue. I wasted so many hours dealing with the dealership and Mazda to acknowlege the problem that saying I didn't have any issue's would be lying to myself.
Other than that I haven't had any serious issue's. Minor problem with keyless entry and that's about it. I'm actually surprised how well built this car is. I abusive the hell out of it and nothing has broken. I don't even know how my clutch is still intack. It hasn't shown a sign of weakness after 100+ launches.
:cool: after one heavier than normal Central Florida downpour my alarm system went haywire. the control module got wet and shorted out. replaced under warranty. A week later after another thunderstorm. the horn filled up with water and shorted out. It was also replaced under warranty. Since then after several more rainstorms no problems.
I had the evap sensor within 1000 miles. Tire wear faster than normal. Within 3000 miles the front tires almost looked like they were no longer balance. Took it into a shop to check the balance and alignment of the tires. No problems so just rotated them.
2nd and 3rd gear grinding under heavy acceleration. Nothing else
No problemo...5,000 miles. Sweet ride. :D
Problems with: clutch, trans, coolant leak, power loss, advanced keyless entry.
Transmission replaced at 8k miles (needed it at 6k but delt with it over a long trip). Third gear would pop out unless under load. I just noticed that the coolant overflow line is leaking so I have to bring that in to get fixed soon. So far I love the car but am weary of drivetrain issues farther along the line.
1 - 20 of 54 Posts
