The car needs to be in "RUN" in order to push start. I have done it, and it is rather easy. If you can feather the clutch to reverse or get rolling from a stop, thats all you need to do it. As far as how bad it is for you car, its good for your starter and electrical system, but isn't very kind to the clutch.I mean putting the key to accessory[/b]
:huh: I guess if you selected reverse and were moving forward or vice versa which reversed the engine's normal rotation it could be problematic.Originally posted by '06 M6 Owners Manual
Do not push-start a vehicle that has a
manual transaxle. It can damage the
emission control system.
+1You are better off calling for roadside service. Waiting the week for them to come get you is better than trashing your clutch.
"Regarding the issue of towing and pushing cars with a catalytic converter, it is perfectly fine to tow a car with one. Push starting one may cause problems if the engine is turning and supplying petrol but not firing. The reason a 'cat' may get its life shortened (but not ruined instantly) is that unburnt petrol is getting on to it, which might happen from persistent push starting where firing does not occur. Push starting due to a flat battery only (i.e starter won't turn) should be fine as the engine should fire as soon as it would when started normally.
One way of prolonging catalytic converter life is to avoid revving or blipping the engine before turning it off as this leaves unburnt fuel on it. By letting the engine idle for a few seconds before turning off lets it settle. Also very short journeys reduce its life as it doesn't get up to temperature."
Shouldnt be any more unburt fuel than if you turned the car over and it didnt start right away...
Seems like a reach for a reason not to do it at best.
I know we did it a million times on my dads old truck, however that thing didnt have the millions of miles of computer cable in it this car does... LOL[/b]
Interesting.So, in my honest opinion, if your battery is dead - running start on a mazda 6 is not an option.[/b]
Yeah this happened to me once in my civic. Damn battery was so dead theres not even enough juice to feed the computer or spark the spark plugs. lolJust thougbht I would mention the following story:
I woke up inside my car outside my flat one day at about 03:00 in the morning with a flat battery and all my windows wide open.
Not sure how it happened (drinking) but was a bit stressed about the windows being open, so I free-wheeled out of my complex and tried to pop it a few times going down the road, this did not work, so I went around a bend and down another road, popped it a few times again and nothing happened.
Some youngsters where busy mounting a protest outside of the "Northgate Dome" where they aparently performed with Will Smith and was never paid, they offered me some assistance and pushed the car down the road whilst I continued to attempt to pop the clutch and get it running - Nothing happened.
I eventually called roadside assistance who came over and within 1 minute from their arrival I had a running car again....
