So I was cruising down the highway at aprox 70 MPH in sixth. As I approached a slight incline in the road I lightly rolled on the gas. Several seconds later I experienced audible knock and an immediate boost / fuel cut. After reading all the stories on here I nearly crapped my self
. Fortunately, everything quickly came back to normal, and I drove the rest of the way home.
I had been regular street driving for about 45 minutes before this happened. BAT was < 130, FP was fine, EGT was normal. I'm running 93 Oct, and have a SMOCC installed. I know about not getting into boost < 3k, and even if I did, it wasn't very far, only had it at about 1/4 - 1/3 throttle. I am prioritizing the AP purchase now to cut the boost.
I noticed during some testing the other day that I would get some KR in 5th or 6th with engine load > 30% and RMP < 3k, but only after warming up for 5-10 min. Could some of this KR be coming from hot plugs
? Would going a step or two with stock turbo @ stock PSI help anything? Will I foul 2 step colder plugs on stock boost?
Thanks all!
Thanks all!
