Speed Limiter Hack
So harken back to last spring when we were talking about defeating the speed limiter:
Speed Limiter Discussion
I have finally gotten around to actually doing it.
DISCLAIMER: This is shared for entertainment purposes only. I do not advise you to modify these systems. I am not responsible for you burning up control modules, making your car unusable or you crashing your car and dying.
Here's what I did - keeping in mind that my intuition nearly makes up for my poor judgement. :grin2:
I unplugged the 28-pin connector to the ABS controller.
I stripped back the harness covering so I could get to the wiring:
After much testing and analysis, I determined there is one wire that when interrupted, the car will continue to accelerate past 120mph. Here is the pin and the wire with blue tape:
I cut the wire and extend the two ends into the drivers compartment:
I ran the wires thru a normally closed pushbutton mounted on the dead pedal:
Re-install the dead pedal in the car:
How it works:
As I approach 100mph, I step on the pushbutton (breaking the circuit to the ABS).
The speedometer drops to zero, the ABS and TCS lights come on.
The car continues to accelerate past 120mph.
As I lift from the throttle, I also release the pushbutton.
The speedo snaps back to life and the ABS/TCS lights go out.
Issues/Risks/Problems/Reasons not to do this:
The wire I found may not be the same for other years and generations.
While the pushbutton is depressed, you have no ABS, EBD or TCS. The big issue is EBD - Electronic Brakeforce Distribution. If you apply the brakes with the PB depressed, you will get equal brake pressure sent to each wheel - locking up the rear wheels sending the car into a spin (ask me how I know).
If something cuts the wires you ran to the PB you will have no ABS, EBD or TCS.
When you release the PB, the TCS is enabled. This is not helpful on the track if you prefer to run with TCS off as I do. You have to reach down (at race speed) and shut it off again. I'm gonna have to figure out how to fix this.
Thats it! Wadaya think??
CR
