541 - 560 of 644 Posts
Nice car and excellent write up. Thanks for posting all that stuff.
I just bought a 2003 M6 to run SCCA -T4 class. Stock cats and springs and has to weigh 3300# I also talked to Mike @ Mazda Today regarding the ECU speed limiter. Also discussed removing every other notch on the speedy wheels. I may do that and see what transpires. Bilsteins ordered next week/ cage goes in soon and maybe on track For Hooked On Driving -Daytona. 12/3 ish .
My best estimate of top speed should be near 135-137. My Chumpcar Nissan 300zx goes about that with 178 CHP.
Discussion Starter · #542 ·
Thanks! I'd love to see your build. Prep for T4 will be much different than mine. Keep us posted or post a link where we can follow along.
Top speed is a problem. I hit the rev limiter in 4th at around 123mph. The .733 fifth gear and 4.133 final drive is a killer. The car really struggles to pick up speed in 5th.
Are you done with Chumpcar and switching to SCCA? I'm just starting in Chumpcar.
Thanks!
CR
Discussion Starter · #543 ·
Wow, that's big news! Congratulations! Any hints on what series? Someone was watching at VIR?
I'll be driving for a Chumpcar team - Endurance road racing - 7, 14 & 24hr races with 3-4 drivers.
First race is 2/7/15 at Barber Motorsports Park. I'll post more of the schedule as it develops. Looks like 4 to 6 events - we will definitely run at VIR (my home track).
I was referred to the team by a former instructor at VIR. The car is a 1991 240SX powered by a Ford 302 V8 - should be a hoot! I'm hoping to get some seat time in the car during a test-n-tune event in December.
Very excited!!
CR
Good luck CR, should be a blast!
Also, 11,000th post....... geez I'm on here too much....
CR, I have put the M6 on the back for now. The lack of a speedlimter fix along with having to run all 4 cats @ 3300# seems like a large hill to climb.
I was pretty sure that it should go a bit over 130.
I really like the car overall and may race one as I still like the numbers for Daytona.
If you say that it pulls poorly at the light weight and power that you have, I am wasting my time and money.
I have run Chumpcar since the beginning(Protech Racing/Ogren). We started with 500$ VW.. Now our team has a Nissan 300Zx that is pretty good. The spread sheet says a little under 10K.
My personal racing is heavy SCCA H Production with 2 VW Sciroccos. geting setup for the Daytona track with megasquirt, fresh engines and very special tires/ wheels/ aero.
Your Chumpcar sounds like Steves, Nissan. They had some issues with heat and blowingshitup. Good luck. We are doing the Homestead 24,Daytona ,Sebring, and maybe the AMP race with WRL.
later,MM
"The car is a 1991 240SX powered by a Ford 302 V8" ... Hp/wt = mucho
The stock rwd 2.4L 160 ft-lb version weighed 2650 lbs. To keep wt distribution good for handling, I bet they move the engine/trans (and you) back close to a foot!
Discussion Starter · #547 ·
Yeah, the firewall has been "relieved" substantially to move the engine back. The drive shaft looks to be a bit over 3 feet long. Can't wait to drive it! :cool:
CR
CanyonRider a bit of advice please, i have read many threads on fusion 3.0 swaps but yours is the only one specific to the 2009 fusion motor to Mazda 6 so here it is, I have a 2006 Mazda 6s and am swapping in the 2009 fusion motor due to catalytic converter failure, I have read many threads and am a bit confused over some of the individual parts that must come from the Mazda engine to the Fusion engine. It's not that I don't want to change them out it's that my fusion motor is almost new (30,000 KMs) and the Mazda parts all have 256,000 KM's on them, just figure less Kilometer parts should work better and last longer if useable.
I know I need to change the oil pan, timing cover and valve covers (optional in valve covers), some threads say upper and lower intake but when I checked the actual parts they seem visually and dimensionally identical and numbers do match 100% on lowers and only last letter different on upper, I figured since the Fusion intake is from a 30,000 KM motor and there is no catalytic residue inside it that it would be a better choice to use if possible (and save me a bunch of cleaning and time). Now to the one that bugs me most the fuel rail and injectors, cannot find a definite answer here, can I use the almost brand new injectors from the fusion or do I need to use the Mazda injectors, I think the plugs are the same but are they wired differently and if so can I just swap the wires around in the connector?? BTW I am using Mazda 6 wiring harness because I hate rewiring crap if I can avoid it. Any advice would be great. thanks and awesome thread.
... My personal racing is heavy SCCA H Production with 2 VW Sciroccos. geting setup for the Daytona track with megasquirt, fresh engines and very special tires/ wheels/ aero....
What year Sciroccos? I drove a 77 1.6L DD for a while, and it was a real fun car to drive. At Summit Point on a track day, there was a later model that was stripped like an SCCA Prepared car, with a 2L euro engine. He was much faster than higher hp cars, as he just flew through the corners with high exit speeds. I also had a 77 Dasher wagon that had perfect pedal positions .. it was the best car I ever had for double clutch heel toe downshift while braking, did it every day comming home from work! Sorry for the OT OP.
Discussion Starter · #550 ·
My experience is the lower intake runners are the same. Some are plastic some are aluminum, but I've never bothered to swapped them.
The upper intake can be slightly different - usually the direction to the throttle body and intake snorkle is slightly different. The Fusion intake can be used if you don't mind making slight adjustments to the intake snorkle.
Injectors are the same - no need to change. My experience is the wiring connectors to the injectors are also the same. Definitely use the Mazda6 harness. I also swap over the Mazda throttlebody and sensors - oil, temp, crank sensors, and TPS, etc. Cam actuators are the same - I don't swap them.
There was a fuel rail change at some point. The early 6s have a female connection on the fuel rail. The later 6s/Fusions have a male connection. Rather than swap fuel rails, I swap the fuel line that runs from the firewall to the fuel rail. Here are the two different fuel lines. The newer 6/Fusion line on top.
Since your car is a 2006, you might have the same fuel rail as the Fusion.
Good Luck!
CR
Good Luck!
CR
Thanks for getting back to me, I appreciate the info and it will help me in re-assembling this motor. The sensors all got swapped with the front cover so that's a done deal, I am using an AEM CAI so a slight angle difference on TB might not be an issue, I will leave intake off until motor is in and decide than but I am leaning towards using the fusion intake if possible, by cam actuators are you referring to the pickups in the front cover , if so I will use the Mazda ones to get car running then swap to the Fusion ones since they are almost new and have no actual running time on them. (Good to know for spare parts to hang onto to) I have attached some pics of the two side by side, and a couple of the internals of the old vs the new motor, the intakes look pretty similar except for a slight upward tilt on the Fusion intake, is that the angle you are referring to?
Auto part Vehicle Exhaust manifold Engine
Auto part Vehicle
Engine Auto part Vehicle Automotive engine part Car
Engine Auto part Automotive engine part Vehicle Automotive super charger part
Engine Auto part Automotive engine part Vehicle Car
Engine Auto part Automotive engine part Vehicle Carburetor
Discussion Starter · #552 ·
No those are the cam position sensors. I was referring to the vvt actuators that come thru the valve cover. Shown in your 5th pic -on the far left.
Yes.
Looks like you got if figured out.
CR
Yes.
CR
Aww the Oil Control Valves for the VVT, yup left the fusion ones in there, appreciate the help. Just got my new seals for the OCV valves and will tackle the valve cover refurbish tomorrow.
My cats failed on the mazda so they are gutted now and I could use them but the Fusion cats look like new (referring to manifold pre-cats), if I leave the Fusion oil pan on the motor and use the fusion Y-pipe they should fit, I can always swap to the Mazda oil pan with motor in the car if the Fusion exhaust cannot be connected to the existing Mazda exhaust, but hey that's what grinders and mig welders are for right, any thoughts on the exhaust, I suspect I would have to swap the O2 sensors since the wiring is different lengths, do you think they would work properly in the Mazda or should I just go with the gutted pre-cats until a header swap is affordable?
Success
Got car started last night and runs good, no cels so far, ended up using the gutted Mazda 6 pre-cats, putting headers on soon anyway, no cels so far, thanks for all the help. Here's a list of what I swapped and re-used:
-2009 Fusion block didn't change anything internally.
-Air induction system: Using an AEM CAI with original 2006 Mazda 6 MAF sensor, cleaned with MAF cleaner.
-TB swapped from 2006 Mazda 6 after a good cleaning
-Upper intake from 2009 Fusion, the 09 Fusion intake has slight upward angle at the TB compared to the 2006 Mazda 6 intake but with the CAI this was not an issue for me. Used this intake because it was spotless clean and my old one had residue from oil and most likely catalytic material, so I was lazy and used the clean one.
-Lower intake from 2009 Fusion
-Fuel rail and injectors from 2009 Fusion
-Front cover with all sensors and pulleys (timing cover) swapped from 2006 Mazda 6
-Valve Covers swapped from 2006 Mazda 6 only because I wanted engine cover to fit, and I didn't have a complete set of the fusion spark igniters, this is optional and you can keep the fusion valve covers if you wish. Just check the OCV seals and replace them if they are bad
-Oil Pressure sensor swapped from Mazda 6
-OIL PAN kept the 2009 Fusion pan, the 2009 pan looks identical to Mazda 6 pan, cannot speak for other years, exhaust fit perfectly, did put in a new seal and cleaned out pan while I had it off. Did not change oil pick up tube, left Fusion one in place.
-EGR valve 2006 Mazda 6, Fusion one is missing tiny vacuum fitting
-PCV valve 2006 Mazda 6
-Pilot guide for clutch swapped from 2006 Mazda 6 (some refer to this as pilot bearing but actually it's just a round locator guide for your clutch alignment tool, not an actual bearing just a large solid metal insert that fits into the crank end and has a hole centered in it to fit the nose of the clutch alignment tool). Some say it's not needed but I swapped it in anyway to make clutch alignment easier, trans slipped right on without any hassle.
Hope this info can help someone else doing the 09 fusion Swap to an 06 Mazda 6
Note all gaskets were replaced with new Felpro gaskets
Thanks to everyone who contributed information to this project, now off to have some fun before I have to put on my snow tires, ZOOM ZOOM!
Discussion Starter · #555 ·
Getting Ready for the 2015 Season
Annual Tech is in about a month and the first track event for the Mazda is early April.
Here's the to-do list:
Oil sender leak
Temp sender leak
Intake air filter bracket
New clutch slave cylinder
Change rear swaybar - maybe?
Back off camber to -2deg
New steering wheel - maybe?
New rear control arm bushings - maybe?
New vinyl numbers and decals
Front spring perch locknuts
Front spring u-bolts
Wide angle rearview mirror
Helmet hook
GoPro Mount
New fender flares
New tires
New brake pads
Driving for another team has cut into my Mazda time (team work night every Thursday), but I'm gonna try to run the 6 as time allows. I'll be driving the team car on Feb 7 at Barber Motorsports Park. First time in a car on a track I've never seen - for a 14hr race . . . what could possibly go wrong! :)
CR
Discussion Starter · #556 · (Edited)
Not in my 6, but my first race. This is my last 2hr stint of a 14hr race. I got us from 18th to 13th. You probably won't wanna watch the whole thing so here's some highlights:
Lap 44: Pass in the grass. Was that wrong? Should I have lifted for the Mustang or was that my spot?
The next car after that pass is the race leader and eventual winner in the black Camaro. Took me til Lap 51 to catch and pass - got a little loose executing that pass. :)
Lap 82: 4-wide pass on the front stretch. I think they told us in the driver's meeting no more than three wide - oops!
http://youtu.be/d7RHB_QG2rY
True to the Carroll Shelby formula, we took a light weight rwd car (Nissan 240SX) and stuffed a large Ford V8 in it (5.8L)
Couple of notes:
You'll see me hitting switches on the dash - that's the pump for the cool suit as I got too hot or too cold.
You see me reach down next to the shifter - that's the radio PTT switch so I can talk to the crew.
We finished 13th of 77 and set 3rd fastest lap.
Enjoy!
CR
That link clipped off the top of the video, so you could not see the lap count, or top of the course map. From your YouTube channel, the same race video shows the top of the video.
https://www.youtube.com/watch?v=d7RHB_QG2rY
and your 4 wide pass, with a high pucker factor at the next turn entry off line ...
https://www.youtube.com/watch?v=5Bxy7Gppnyw
Lap 44, 0:47, you had left lane position on the Mustang comming at you. If you did not move left, contact would have been front wheel to front wheel.
Lap 79, 1:41, transition from closing radius right at 14a ... back end popped out as you straightened out the car for right at 15. Looked like a moment!
Discussion Starter · #558 · (Edited)
Thanks Kevin. Yeah, HPDEs are great for learning "the line", but when there are 77 cars on the track, you quickly learn the limits of your car "off line".
People underestimate the focus required for endurance racing. The race was 14hr (7hrs Sat & 7hrs Sun). I had done 2hrs 20min on Sat and when not driving, I'm crew. So by the 2hr Sun run in that video, I was feeling weary. It doesn't take much of a mistake to find yourself pointed in the wrong direction. I have a whole new respect for the pros!
I'll be taking the 6 to VIR in April so I've been busy in the shop. Lots of little thing mentioned before, but one major item. I'm replacing the flares. The old ones were OK, but the ABS is not durable and after 2 seasons of hitting cones and trailer loading, they are busted up. I picked up some that are fiberglass and about an inch wider.
Waiting for it to warm up so I can paint them, but the mock up looks pretty good.
You might notice I've been playing with some vinyl recently also.
CR
I think around page No 49, you were thinking about less rear bar, like the 22.5 from Steeda, with RB up front. IMHO, that would be too big a change vs the 27mm RB rear. The 24mm Progress bar would be a better choice. And you could mod the ends for a stiffer setting, if needed.
Another option would be to convert to split-aluminum pivot blocks, vs the poly bushing + bracket. I had these on the GT-6 I built with SCCA DP mods per the "Triumph Competition Depeartment" as a guide. I used nickel based antiseeze paste for lube (solids in paste for Boundary Lube Condition). Never a squeak, and the bar would swing down freely when end links were removed.
Based on my "pestering", Phate from the MSForum just did measuremenets of the oem front sway bar rate, with poly pivots. It turned out that the tested rate was about 1/2 the theoretical rate, per the Puhn formula. We concluded it has to do with the rigid body motion of the bar in the elastic bushings. This effect is due to a high ratio of the distance between bar end holes, divided by the bushing separation, squared. His front bar has the same geometry as the M6. This effect is minimal for the rear bar, as these two distances are almost equal.
http://www.mazdaspeedforums.org/for...tein-coilovers-161806/index7.html#post2784655 -Test Rig
http://www.mazdaspeedforums.org/for...tein-coilovers-161806/index8.html#post2787853 - Rigid Body Motion
So if you added aluminum pivots to the front bar, the actual rate would increase about 60-80%, based on Phate's test, for less oversteer.
Almost forgot, congratulations for your excellent entry into real racing, endurance at that! Based on your ability to alter lines at the last minute, and to keep everything working for 14 hrs, do you run at less that 9-10/10th through the curves? Like I noticed comming out of 7b, rather than shifting to 3rd, you kept it in 4th with rpms at 2K, then wound it up to 5k for the shift to 4th. Even with some modulation for traction, it looked like it would be faster to downshift.
