1 - 20 of 78 Posts
Well, from what I understand is higher the compression ratio, higher octane fuel is needed for the engine. But from Mazda's PR brochure, it states the high 13:1 compression ratio allows it to run on Regular Unleaded.....
So....what is the best grade of fuel for this car? I've been putting Premium out of habit and been getting ~30mpg after 1800 miles with very light foot on the gas. What you guys think?
Doesn't need premium. The "Skyactiv" explanation will take you into the weeds but it means they found a way around the issues -- you can use regular despite high compression.
I put premium in by accident a couple weeks ago and it did nothing for my mileage - Still about 31 in mixed driving with a slightly heavy foot.
Definitely regular fuel for the 6...
Discussion Starter · #6 ·
I've always used Shell cuz that is the closest to my house and they are generally only couple cents more than RaceTrac(cheap gas) across the street. I don't believe QuickTrip is a top-tier, they seem to be priced too cheap to have good fuel additives.
Here's the list of Top Tier gas companies:
Top Tier Gasoline
TOP TIER Gasoline Retailers: (US)
76 Stations
CountryMark
Entec Stations
Exxon
Hawaii Fueling Network (HFN)
Holiday Stationstores, Inc.
Kwik Trip / Kwik Star
MFA Oil Co. Mileage Stations
Mobil
Ohana Fuels
Phillips 66
Quik Trip
Rebel Oil
Road Ranger
Severson Oil
Shell
Texaco
Tri-Par Oil
Co.
U.S. Oil
Ewwww STP
New cars don't benefit from it if you use good fuel - BUT if you ever need to when it has more miles:
The only real effective active ingredient in fuel cleaners is PEA .
So the more PEA you have, better it works. No PEA, or very little, like STP - snake oil/scam
Here's a list of 'real' fuel cleaners and rough estimates of PEA in them
* Chevron Techron Concentrate (32% PEA - some say that Chevron sometimes claimed even up to 45% )
* Gumout Regane (30-40% PEA content based on published MSDS data; about $5 for 12oz. bottle)
* Redline SI-1 (30-50% PEA based on MSDS data; about $9 for 15oz. bottle)
* Amsoil Performance Improver (28-37% PEA based on MSDS data; $10 for 12oz. bottle)
* BG Products 44K (??? unknown PEA content)
* 3M fuel system cleaner - about 40% (but not confirmed)
Of the above, only Techron and Red Line are approved by car makers. (BMW even sells Techron in the same bottle with a BMW label)
I have used RedLine and Techron on my older cars (Never did any type of testing about MPG or whatever, but i can say they never had any fuel system related problems - but i can't say that's because I used those; I guess it doesn't hurt and might benefit in older, short trip driven cars, so why not, in reasonable intervals?).
Techron conc. is very easy to find at many AAP or AZ stores and often have buy one get one free sales.
Redline SI-1 has the added benefit of also being a UCL (Upper Cylinder lubricant) and can be used in little maintenance doses also.
I really would not use any in a new car, but when it passes 75k or 100k miles, then I think one might benefit from it.
No they don't have to display any logo.
It's not an assumption - they gets certified as 'top tier' when they have a certain minimum amount of certain additives in gas.
I have a friend who drives the oil rigs to various gas stations, so these additives from shell chevron etc etc when do these additives get added because he said he will go to a shell drop off and then go to BP and drop off.
I never put premium in my mazda buy my Acura I did since it was necessary.
1 - 20 of 78 Posts
