Hi, i have a annoying problem, when i start driving and take clutch pedal up my rpm will go low, car start to vibrate and headlights will dim. It takes couple of seconds to get rpm right and then car will take off like it should be. If i give it a little bit gas it will work properly, but this isnt solution. I have new spark plugs, 1year old ignition plugs and distributor and new car battery. Any ideas?
Does the car stop quicker than normal when coasting? Bad bearing or stuck brake caliper?
Do you have a vacuum leak? Check the intake hoses and the accordion tube from the air cleaner very well for cracks.
Do you have any engine codes?
Could bad grounding do this? Just noticed that my fuse box terminals both sides of main fuse are pretty damn corroded.
Any tips to clean those? Battery off for sure but anything else?
