I got a used AEM intake and need some info on putting it on. Anyone have step by step install info or pictures I can see?
Thanks alot,
Will
Thanks alot,
Will
http://www.mazda6tech.com/index.php?option...9&Itemid=49
thats for a v6, but its pretty much the same thing. There is one hose on the front side you will be removing with the stock airbox, and you will need to plug that hole up once its removed. hopfully your new intake came with that little nipple peice to plug that up.
Discussion Starter · #4 ·
I did search couldn't find anything on 6i. By the way what does ftw mean?
No nipple for the plug. What do you think might work?
Thanks.
Thanks.
Extend the hose into your car and while your driving just use your finger to plug it.
... I'm sure you can find something, small screw or look around Home Depot. :)
