Does the PCV valve problem exist in the '06 or '07 model? Is it as much of a problem on a stock engine? I'm considering buying a 6s MTX, and I'm trying to get all the info I can. What about engine mount problems?
The engine mount isnt really enuf of a issue to stop you from buying the car.. if it becomes an issue you can always get the cp-e engine mount which is a better mount anyway... and the PCV valve isnt a very common issue out of the thousands of people who own the car only a few have that problem. As long as you keep an eye on your oil as you should in every car reguardless you should be fine.
um.. well anything is possible i guess... but we havent really noticed any kind of trend as to which mods would cause it.
i would say more than only a few have had the pcv problem, but there is a thread around here somewhere that tells you how to install an inline pcv as a backup to the factory as a failsafe, so i say if a 6 is what you really want buy it, and just buy and install the cpe mounts and an inline pcv. but since your getting the mtx plan on buying a new clutch around 30,000 miles, unless their using different clutches now from what the were using in 05-
