1 - 2 of 2 Posts
Hi All,
Is there anyone out there who has both a Parrot BT Car Kit and the AudioLink ipod kit. I have both of these and they are both great products, however when the installer fitted the Parrot, instead of using a proper wiring adapter harness they just cut and spliced the parrot harness, and instead of nicely muting the radio, they have taken the parrot mute line and fed it through a relay which simply cuts power to the radio and is a bit irritating.
What I want to know is if somebody has both these and it has been installed using a proper harness, what happens when you get a call on the Parrot - does it mute the radio as if you pressed mute on the steering wheel? Does it show 'mute' on the radio? and most importantly, does it pause the ipod?
Thanks
1 - 2 of 2 Posts
