I replaced the stock parking light with an after market xenon matched LED bulb found here 194 168 W5W 2825 Map Led Parking Signal Marker Bulbs and it looked awesome, especially with the xenons turned off.
The problem is that about after 1 month of use, the driver side bulb would intermittently stop working until it permanently stayed unlit. I went to go check it and it fell into the headlight unit as I pulled out the bulb socket. I spent about an hour sticking my hand in the headlight and finally got it out. I placed it back into the bulb socket securely only for it to come loose 40 miles later and again fall back into the headlight as I tried to remove it.
This time I couldn't get it out but luckily it's not visible from the outside. I never had issues with the stock parking light. So something is causing the LED bulb to become loose.
Is the LED bulb becoming loose because of the worn bulb socket or did I purchase a faulty bulb? I'm afraid to try a different bulb cause I could risk the bulb permanently getting stuck in the visible part of the light assembly. Also, could I use just a tiny bit of craft glue to hold the bulb in or is that a bad idea? Unfortunately there is no way to lock the led bulb into the bulb socket. It just slides straight in.
